How do you get Suffolk Engine Shroud off?
Daggerwin
I know it sounds stupid but how do I get the shroud off this Suffolk engine?
The cylinder head cover and flywheel cover are usually in two parts but on this engine they seem to be stuck together. I can't get it off because when I lift the main cover up the cylinder head cover catches on the head bolts.
It's hard to explain so I added a picture.
How would I get this shroud off?
Thanks
Could you take the bit the starting rope goes on and lift it up,iv never seen one before where theres 4 bolts going up from the cylinder head.
That's not the way they should be, someone been there...! I have a good clean engine (running) here in South Wales if you what it, PM me.
