How do I measure Engine Speed?
Go-Rebels
Is there a technique to measure engine speed (RPM) on single cylinder engines in general? I don’t want anything permanent; I only want to know if I’m reaching maximum spec’d speed.
I bought a little "laser" tachometer from Harbor Freight for about $20 or so, works fine for stuff like this. Uses an LED that you shine on a rotating piece with a small strip of shiny foil or tape on it to give it a pulse to measure.
