No
On the starter solenoid battery lead will be a red wire with a ring terminal ( not the one at the bottom with a spade / blade terminal ).
Follow that and it will lead to a fuse, replace the fuse .
Follow the negative battery lead to where it bolts onto the mower, make sure the bolt is tight & the joint is clean .
