warrenpeas
- Nov 29, 2017
- 6
- 19
i have an old series 6 with the 3 prong ignition switch. is there a way to test the ignition switch to see if it is bad? If i jump the solenoid with a screw driver it turns the starter and starts fine and I replaced this solenoid 2 years ago with a new one. If i take the wires out of the back of the ignition switch is there a way i can connect them together to bypass the switch to see if it activates the solenoid?
