HOT PROBLEM
MOWSCAGG
I HAVE A PROBLEM WITH MY TIGER CUB. (KAWASAKI 19 HP FH 601V) WHEN IT GETS HOT IT SHUTS DOWN AND MUST COOL PRIOR TO RESTARTING. NEW COILS HAVE BEEN INSTALLED AND PROBLEM REMAINS. FUEL SYSTEM SEEMS TO BE OK. PLEASE HELP. WHAT HAVE I MISSED ? THANKS IN ADVANCE FOR ANY HELP.
Check and adjust your valves all to .004-.006 of an inch.
ADJUSTED VALVES @ .006. INTAKES WERE OK. EXHAUST WERE .010. MOWER STILL SHUTS DOWN BUT TAKES LONGER TO DO SO. ALL FUEL LINES AND FILTER HAVE BEEN REPLACED AS WELL AS THE SPARK PLUGS. WHAT HAVE I MISSED ?? THANKS IN ADVANCED FOR ANY HELP.
GOOD QUESTION. I'LL TRY TO FIND A PRINT OF THE MOWER AND CHECK FOR A SWITCH. I DID UNHOOK THE KILL WIRES FROM BOTH COILS AND IT STILL SHUT DOWN. THANK YOU FOR YOUR HELP.
Did you check for spark when it shuts down. No spark coil problem, spark fuel problem. If it's a fuel problem, start by checking the fuel pump when it shuts down.
What type of oil are u using if its to thin it will get hot ..If there is grass build up under the engine covers that could cause it also
