reynoldston
Put new gasket on every time you remove a part that has a gasket on it including head gasket.
Why? If the old gasket is good why change it?
Once you tightened the bolts down it smashes the gasket and leaves a impression on it. So do you think will happen if you tightened a up carb, cylinderhead gasket, etc. that already has that impression on that used gasket? It will probably have air leak, right?
I see one more time we don't agree but that's OK because we don't have to. I don't change every gasket on every job if the old gasket is still good and I don't have leaks. Yes I will change a gasket if it gets hard, brittle, and breaks. On some of the older jobs seeing its hard to find new gaskets, its even more so. On them I will use a sealant or if need be make a new gasket. This also go's for seals and bearings which if they are still OK I don't replace them. I can be a little a little on the tight side when it comes to spending money when I don't have to.
You might want to look into some of the newer sealants. They have come a long way on them since the horse and buggy days. One heck of a lot cheaper then changing parts for no reason. You have a very good plan there but you sure wouldn't be working on my equipment. Some cases don't use gaskets at all but use anaerobic sealant. What do you do there just replace?
I haven't ran into anything that doesnt use gaskets and just the anaerobic sealant yet in small engines. In automotive I would inspect the part warp with a straight edge and use sealant if the part isnt warped or damaged from wear.
I know my buddies shop would replace the head gasket instead reusing it. His shop stay 4-6 weeks behind in the spring/summer and probably 2-3 or 3-4 in the winter months.
Now we aren't talking about a shop here but a home owner that did the repair on the kitchen table??? I don't know what your buddy doses for repairs. But if he has a unlimited parts supply good for him but I don't and the OP didn't. Now didn't I say I do replace them when I can and I am sure the OP would of if he had one. I even have to go to mower salvage yards to buy used parts that aren't made anymore. Your buddy must work on all newer equipment or I am sure he would run into the same problem unless he knows of a place that sells new old stock? If so let me in on this secret place.
