Hi. My first post in this forum!
I ran my Honda HRX217HZA with the GC190 engine dry of oil stupidly about a month ago. It seized up and I thought I was done until I started googling it. Apparently a lot of times the piston can be freed with some penetrating oil and a wrench. I removed the spark plug and the top cover where the pull cord is housed. This exposed a nut that is connected to the motor shaft. I was able to free up the nut and everything turns as it should. The pull cord now pulls. However, I am not getting any spark so nothing is happening.
In the process of figuring out the spark problem I noticed that I do not see any piston movement while turning the motor. I look into the spark plug hole with a flashlight and nothing moves. Does this mean I have a sheared part between the motor and piston, or is this normal? I'm not going to pursue the spark issue if I have a stuck piston.
Thanks for any comments!
Dan
