Thebrickcounter
Hi all
New here.
I am trying to replace the drive belt but after removing the plastic shield tray to get access to the drive shaft/clutch I'm unable to undo the centre bolt as it just rotates with the rest of the engine as if it's trying to start.
I need to stop it spinning so I can undo the centre bolt.
I have removed the blade but as it spins with the flywheel I can't remove to get access to the pulls/belt.
I have looked at YouTube but they seem to have either not the same mower or have no problem with it all turning together.
I've noticed dish the side there is a notch in the metal wheel which may be how you brake it to stop rotating??
Any help appreciated.
Ben
New here.
Ben
