Honda HR214 SM
Mike88se
Got it all disassembled. Pics here in my HR214 album: album
Strong transmission/transaxle
drive joint (drive shaft?)
Blade brake AKA roto-stop
Complete starter assembly
control parts from the mower, some are SM specific and some fit all HR214 models I believe
control panel including key, battery holder/bracket, wiring harness
Matter of fact all parts for electric start conversion including the flywheel and the lower handlebar where the control panel mounts.
I jumped the starter from my other mower's battery to verify that it works.
ignition coil
charging coil
throttle & speed control levers and housing
All cables are good.
The deck is great too. Now that everything is removed I'd guesstimate shipping at $30 to $35
Mike88se
Went ahead and put it all on ebay. Hope I make some money back :)
If anybody is interested I removed the head and it looks like the smoking problem might have been valve guides or something. I didn't see any oil leaking past the rings.
Rknash48
I used to have a Honda HR214, and I repaired it myself, it is great outdoor power equipment!
