taongisurvivor
- May 8, 2020
- 3
- 4
After 38 years, time to rebuild the old girl. Tear-down was straightforward and since I have used Mobil1 oil since new, the inside was in remarkable condition. Bought the shop manual and was careful to only get Honda parts. Assembly now started and I've come across a thick washer with an ID just perfect to go at either end on the crankshaft. Could not tell where it came from as when I separated the oil pan from the cylinder, some parts just fell out before I could identify their location. The shop manual does not identify this part. Anyone have any ideas?? A thrust washer for the crank?? If so, goes at which end
