I have recently changed this motor from a push to a self propelled. On starting the engine it now revs at extremely high rate. (don't think it could rev any higher).
What do I need to adjust to correct this? Could it be the governor inside the motor in incorrect position? Carby not touched at all. Valves adjusted, exhaust 10 intake 8. Is this correct settings? Found marks on Cam & Crank shaft, all lined up. When pulled to start, ran on second pull :smile: Can any body help please?
