Chuckyboy1980
I am completely out of ideas with this.
I have a ransome bobcat with a Honda GV400 engine. All was working fine last week stopped to have my dinner then wouldn't start again. No spark.
After stripping it down the coil was tested and showing an open circuit. I ordered a new coil pack, condenser and spark plug cap and plug. I rebuilt it and still no spark. I tested the coil and get a resistance of 13kohm, between the HT lead and laminated coil pack. Tested the condenser and it appears to do as you would expect on the meter. I have cleaned the points and checked them with a meter and they appear to work correctly. I have isolated the coil from the stop button just to make sure there is no faulty connection in the switch.
Has anyone got any ideas?
My only thought at the minute is the coil pack and condenser have 3 wires to connect it's possible I have one in the wrong place.
1 wire to the condenser and from condenser to points.
1 wire or the stop button very obviously the stop button
1 wire which I think also goes to the points, same terminal as the condenser lead.
I do think I may have the last wire connected wrongly but I was sure I wired it up as the original was.
The only other thought was the magnet strength but it appears as strong as you could expect.
Thank you for any thoughts it's very frustrating and I would hate to bin the engine.
