- May 6, 2010
- 12,009
The best explanation is spark plugs do weird things on Honda engines. And it doesn't matter if it is the GX/GXV or GC/GCV or even the TRX engines.Absolutely makes no sense to me but the new plug solved the problem!! WHY??
Thank you so much!!
Will spark until warm and then start sparking, Will run a few minutes, and then die, and attempting to start just causes a backfire, or my favorite is the spark plug is sparking but jumps the gap between the center electrode the side of the plug instead of the electrode sitting just .030 above it.
