JDgreen
- May 14, 2010
- 248
- 2,887
Have so many leaves, I hate to mow them over with a mulching push mower. Made this deck block off plate from aluminum stock, you cannot see the "L" brackets, but they are slotted so I can adjust the distance between plate and deck opening. The pic of the leaves shows how well it will keep them in the deck to be chopped up with the plate fully shut, and in the position shown, partly open, my once detested 7-Iron deck does a much better job of chopping up DRY grass than it formerly did, because the plate keeps most of the clippings inside the deck where the Gator blades can chop them up better, when it formerly blew all the grass out the chute before chopping it up. It still windrows, but nowhere as bad as it used to.
