High wheel push mower recommendation?
ezzrider
I am looking to purchase a high wheel push mower to use on my property. I already have a Kubota Tractor with a 5' rear mowing deck that runs off of the PTO. I just need a push mower to mow places I cannot access with the 5' mowing deck. I have a 6 HP Murray High Wheel push mower that the deck just rusted through on the back at the wheel areas and I cannot use the mower. I do not need or want a bagger or self propelled. I also do not want to spend a fortune as this is only to use where the 5' mowing deck cannot access. Any suggestions?
Hi there, I used to have a Husqvarna R53sv until a guy who worked for me smashed the shaft on a drain cover! before that it worked pretty good.
It was front wheel drive! but this worked well as you could simply use the huge back wheels to pivot it over higher stuff when needed or when turning without letting off the power at all. - Could side discharge too which left a lovely finish.
Handy machine.
I've had good luck with Craftsman. Here's one that may fit your needs for $200.
Craftsman 6.75 Torque 190cc 22'' Briggs & Stratton Push Lawn Mower
Sold by Sears | Sears Item# 07138528000 | Model# 38528
