And think the DIYer has been using this mower for nearly a year before he decided to bring it to my shop.
When it did come in it had multiple problems. Five listed below. Three of which he induced.
- Carburetor was dirty.
- Both intake manifold o-rings were damaged.
- Fuel pump impulse hose was the wrong one, installed incorrectly, and had develop holes.
- Rocker cover was leaking due incorrectly applied RTV sealant and looked like the wrong type.
- LF tire going flat.
Fix all these to just get to the root cause of the surging and it is one not normally seen. I had one similar to this a couple years ago so it was still fresh on the brain cells. It had to be a valve train, spark related, or governor issue.
First I check the exhaust to see if it was a completely dead cylinder and it wasn't. Still surging holding the governor arm steady so that ruled out a governor issue. So I was just going to a try a new set spark plugs when I found the stupid mistake made by the DIYer and its one that can happen to any of us if we just skip a vital step.
What was the problem you ask. It was the spark plug tip air gap. It was only .002" when it was suppose to be .030". This was causing a random miss fire and an ignition timing problem.
Normally you don't see this; unless, there is impact damage which there was no sign. So it had to installed that way.
Isn't experience a great teacher? Have a problem that gives you heck to fix once and it will stick with you.
Now it is time to move on the X360 here with a FH661V that been sitting a couple years in a storage building. First I got pass all the rat dropping and I do mean a very large amount of rat droppings and not mice. It even has some cow pies on the tires. Time for the mask and rubber gloves.
