StangOne50
Hello everyone. Im having an issue with my mower. First here are the specs..
2007 Craftsman 12.5 HP 30" Hydrostatic drive Model 536.270340. Its pretty clean and maintained as far as oil,plug, fuel and air filter.
The issue I am having is that I can drive for about 20 seconds and it just comes to a stop. It does not shut off, just stops moving forward. To get it moving again I have to put it into reverse, drive for a second then I can push the speed lever back to the forward position and it will drive again.
It happened whether the blades are engaged or not and been happening since last week or so.
Things I have done or tried so far..
-I adjusted the clutch 2 turns. After this I still have the same issue except that it drives a bit further before it stops.
-I visually inspected the upper idler pulley and belt and they seem to be moving fine. While running if I press the clutch it loosens the belt and it tightens when I release the clutch pedal. I sprayed a little wd-40 on the idler pulley arm just incase.
-I drove it making sure the clutch spring was fully disengaged and when it stopped moving I checked underneath and can still see the pulley and belt spinning and when I move the speed lever into the forward position I can hear the sound of straining a bit.
Should I try tightening the belt even more by adjusting the clutch? It seemed I could still turn the adjustment bolt but I dont know how far to go with it.
-I let it run up on jackstands and the wheels did not stop turning.
One thing I noticed is that the clutch pedal does not fully disengage when the pedal is released. There is a spring that does not seem to be pulling it back fully.
Here is a photo of the spring after I press and release the clutch...
And another photo of the spring in the position it should be when the clutch pedal is released...
Now Im wondering if it is simply this spring causing my problem by not fully disengaging the clutch. Is it safe to spray this area down with wd-40?
This is the belt which looks ok to me...
