help with le14.538h engine throttle issue
bigdaddy65355
ok i labeled this as a throttle issue not sure what to call it but, here i go i have a snapper le14.538h i am new to mowers as this is my first one and my issue is that it has a lever for throttle adjustment to go past half throttle causes it to bog down and die also if i run if for more than 3 minutes after i shut it off once the engine comes to a stop it pops really loud out the exhaust can anyone help me ? this is my only issue with this mower other than for the life of me i cannot find a cheap discharge shut for it.......
mechanic mark
bigdaddy65355
thank you for the link it helped a lot but as far as the throttle issue yes letting it idle for 30 seconds stopped the backfiring but with the throttle as shown in the picture it shows full throttle at the top but you may be right it could be a choke symbol but i am not sure this is my first rider and im still figuring some of the things out, that is why i am uploading an image..IMAG0107.jpg
All the way up is the choke position used for cold start. About 3/4 of the way up there is a V notch which is the full throttle run position.
bigdaddy65355
yup in that link to the discharge chute that was replied before i found the manual on there, downloaded and read it and yes you all were right it is the choke position. thank you all so much for being here to help me i appreciate it.
