Just got this 1995 John Deere GX75 rear engine rider. Challenging to use on my lawn (not flat). It cuts and bags well but I need to stay in 1st or 2nd gear in order to move. Slow! I like the size of this 30" deck. The belts are new, I'm told. It also goes well in reverse (thank goodness I can back it up the ramp into my shed). Any ideas as to why I am getting stuck? I have had to put my foot out to push. I do not have a manual. I don't know if it's a transmission problem, a weight distribution problem, or what. Should the deck wheels be set high? Also, is the choke setting on the throttle, the turtle, rabbit or the one in the middle?
Any owners out there with this problem? I would really like this mower if it moved better.
these were great mowers, but the issue with the transmission is pretty common. But really it isnt the transmission, if they have been sitting for awhile, the CVT, or constant variable transmission would stick. If your belts are ok, there are two under there, well that is what you have to look at. Most dealerships wouldnt even touch these, or even charged extra to do the belts on them, cause you almost have to drop the transmission to change belts, and on a few models you had to drop the transmission to change the brake pads on them. The variator- if thats what your problem you have with it, its hard to get you any help without being right there-sorry, this piece use to be over $400 for it. I dont know how much they are now, or how much they charge to change them out. If you were around me i would give you one extra that I picked up, just cause I dont need it. But this piece is what actually give the transmission its speed, its one belt spins fast and squeezes the pulley to give the other belt speed or to slow it down. Check you belts first though, maybe one is worn out or broken, fell off....
#16 in one picture and G in the other.
Hope this helps
BTW, I have been able to free up the CVT by working it back and forth with no belts before, it can be done and is a good winter project if you need one
