Help what engine do I have
kchudy
I got an MTD mower from a friend and the engine does not have the original shroud on it so I dont have a model number. is there any other way to tell what model engine I have so I can buy parts for it. I have reason to believe that it is either a 14.5HP OHV IC or a 16HP OHV IC and not the 18HP that the shroud says because the breather is different. any help I can get will be greatly appreciated.
Just what kind of parts do you need. I would take the chassis model number and see if you can cross it over like that?
I just need to get all the gaskets and I would like to get the correct shroud for the engine. I called MTD yesterday and they told me that my model and serial was built with an 18HP engine. I started taking the engine apart and noticed the differences and it just has me wondering what engine I actually have.
MTD/ Yardman? model 13BP605H755 Came with a Briggs & Stratton 18.5 with 18 HP engine, 7 speed transmission and a 46 inch deck . No idea what you have because I don't see any model numbers? Don't know if this helps or not?
