L.skynrd
- Apr 4, 2021
- 2
- 5
Hello everyone. I have this vintage Briggs and Stratton 3hp engine that I am restoring. I replaced the old breaker points ignition coil, to the modern electronic magneto coil. After I did that, it started right up and ran perfectly. From there, I removed the carb and gas tank, so I could repaint the engine. I reassembled everything and when I attempted to start it, it would not go. I sprayed starter fluid into the intake, and it would fire slightly, but did not come close to running. I am not sure what the problem could be. I cleaned the carb out. I Have a good spark plug, and new gas. I also replaced the flywheel key, as I misplaced the original one. The oil appears to be clean. I also feel compression. I reused the gaskets, but I am wondering if that may be the problem. I have no idea at this point
