Help resetting the beeping on a RED Equipped Lazer Z S Series ZTR
aylor11
  • / Help resetting the beeping on a RED Equipped Lazer Z S Series ZTR
Hello, new to the forum. I have tried to find a RED user manual with no luck for some reason. I just purchased a 2018 Lazer Z S Series 60" ZTR and I performed the first oil change (first 8 hours) but I cannot find a way to stop the beeping and turn the red light off to show that it was performed. Anyone know how to reset the oil change and turn off the beep and red light? Thanks in advance.
Not sure about your mower, however most reminders stay on for 1 or 2 hours then self clear.
aylor11
Did not work but thank you for the suggestion.
BlazNT
Need the Model number and serial number.
geelee
sit on seat. turn key on-off-on off-on- off- on. leave key on. wait for oil change icon to come on. pull right hand motion lever in toward you, then push lever back. turn key off. oil minder will reset. this will reset the type that doesn't have the 3 buttons for speed control . if it is that type turn key on hold 2 outside buttons down menu will come up super secret code is 1982 to reset .
