I have a classic 2760, with about 130 hours on it. The past 3 weeks I have had to work on it, in some form or fashion, for each use. I just replaced the factory battery, because it went bad, with a Die Hard - Yesterday, this new battery was stone cold dead - I found a 30amp fuse blown on the engine, would this have something to do with the charging system, maybe?
After jumping the mower to mow yesterday, I shut my blades off, to cross a driveway. On the other side of the driveway, I reengaged the blades, and nothing, just able to hear a relay click. I parked the mower, after looking it over, I found a plug on the right hand side, under the seat, with a purple and black wire, but I could not find anywhere to plug it back up. (see attached photos) After jumping the battery to put it up for the evening, the blades would then engage. Any ideas on why the blades were intermittent, or what this plug goes to?
I have also noticed that occasionally, I am pushing my control leavers forward, but the rear wheels don't always respond. I got stuck yesterday, which usually is not an issue, but I could not, for the 1st time ever, get my mower to climb out of the hole. It was like the response to my commands, from the control levers, to the rear wheels were delayed, and would not spin fast enough to throw a rooster tail, just a slow spin in the mud. I opened my hydraulic tank, and it is full of fluid. Any ideas here?
This has been a GREAT mower for me, until now. I bought it new in 2010. This will be my 4th mowing season with it, and for a model that is only used residential, with just shy of 130 hours, I am starting to question the durability of the Dixie Chopper legacy.
