This is why I do voltage drop tests under load. The bad connection usually will read voltage across it when it should be reading near zero volts if the just a connector or contact involved.Three words of advice from someone who does auto electric troubleshooting, firing the parts cannon should not become an option. Very expensive. When checking electrical connections, do not use only a meter. The high input impedence will show the worst connection as good. Use a test light, not LED, to verify that the connection or switch is indeed good. A high resistance connection will look fine with a meter, but unable to light even the smallest light bulb. And also, start your testing with clean and tight battery connections. Again a corroded battery terminal may look good from the outside, but underneath there may be high resistance that would steer you back toward that parts cannon.
And I had a few battery terminal connectors to be bad internally too.
