HELP... Log Splitter Issues B&S engine
Todd J
My neighbor has a log splitter from Tractor Supply. It has a B&S 675 Series engine. The problem is that engine will not start without holding choke shut manually and then working throttle by hand. I am sure there is a spring or rod missing on carb. but not sure what or where it goes since I didn't see it before. He loaned it to someone and it came back broke. The model of the engine is 126M02-0432-F1. Here are a couple of pics of carb. hopefully someone can help.
Take the air filter off and the air box....... 3 bolts holding it on and post a few more pics......
I work on those all the time......
Where you at in Louisiana ??????
The reaso I asked for that is I don't see a choked style carb...... Do you have a red primer bulb in the front of the air box ???
Not sure what you are calling the choke since that carb doesn't use a choke because it is a primer engine. I suspect the problem is a dirty carb, or bad gas that is causing the issues. I don't see anything missing from the carb area, and everything looks like it is in the correct location. Wouldn't hurt to clean some of the junk out around the little metal kill tab next the small plastic square, could be shorting to ground and causing ignition issues.
I can bet good money his main jet is clogged up .............. And you are right on the spot with the kill tab ~!~!
Todd J
Yes, it does have a primer bulb in front of air box. Will have to get more pics tomorrow. Too dark now.
I live in Pride, La. just north of BR
I know Pride in fact that's where Elly May Clampett is from and buried there...... Take off the bowl nut but leave the bowl on for now.....
There are 2 holes at the bottom of the nut and 1 on top clean those out well and do what IL Engine said......
You should be good to go..... Don't worry about the xtra pics I asked for .............
Plus Tard Mon Ami ~!~!
Russ2251
Please note that in 2nd pic primer bulb is collapsed (sucked in).
Todd J
Thanks Guys, I'll try this tomorrow and let you know how it goes.
Yes I can see the bulb now that I looked good ..... It's Normal to me they do set inside like that .........
Todd J there is a hole in the middle of the bulb.... That's normal on those style engines.....
