Help identifying my Hustler
JDS Surf
I recently acquired the Hustler in the photos and I am having trouble identifying the model.
It currently does not run and I am hoping to get it running to use around the place. It is powered by a kohler engine but again I have no idea what model the actual engine is.
I have been able to get it to crank but even with a bit fuel down the carb I am not getting it to fire, closest I got was flames coming out of the carb.
Any way, any info or and ID so I can find some repair / workshop manuals would be great.
Thanks in advance for the help.
IMG_7642.JPGIMG_7651.JPGIMG_7650.JPGIMG_7649.JPGIMG_7648.JPGIMG_7647.JPGIMG_7646.JPGIMG_7645.JPGIMG_7644.JPGIMG_7652.JPGIMG_7642.JPGIMG_7651.JPGIMG_7650.JPGIMG_7649.JPGIMG_7648.JPGIMG_7647.JPGIMG_7646.JPGIMG_7645.JPGIMG_7644.JPGIMG_7652.JPG
Tomster
Hustler 400?
Hustler 24696?
Tomster
I don't know, I just did a little snooping on google and found the model numbers.
Start with the engine.
Most will have a serial number which has a date code in it so that will give you a year.
Noah_Phence
Hi,
Not sure if you are still trying to identify your machine, but from the photos it would appear to be a Model 272A which is a 1970s era Hustler product.
