Oi when I jump the solenoid if fires hard and fast, but when I use the key it click or drags/bogs trying to turn over the engine. 98% of the time it clicks and after maybe 3 turns of the key it will turn over. I have smacked the solenoid with a wrench while holding the key and it would then crank.
The contacts have been cleaned... I guess I could/should change the positive wire as I did see some green corrosion inside the end of the cable.
I just don't understand why it bogs down using the key, like something is robbing the volts and not applying it to the solinoid.
