Help for a newbie!!!
jefferoni
Today I got my 22" 6.5 hp Craftsman walk behind out of the shed for it's first use this spring. Wouldn't start. Checked gas - mostly dry. Filled gas. Wouldn't start. Small squirt of starting fluid. Started then died. Repeat. Removed big screw (drain) and fuel hose from carb. Used gentle air pressure on these two orifices. Reassembled. Started mower. It is running very very rough acting like the timing is off or?? Chugging out big puffs of blue-back smoke. My best guess is that it's getting way too much fuel.
Opinions?
Answers?
Serial and model numbers: 012379M001111 917 377 270
Engine number: 1439765007006K
Thanks in advance,
jeff
Opinions?
Answers?
Thanks in advance,
jeff
Have you cleaned the air filter could have oil in it.
Start it with out the filter and see how it does.
Is the oil over full or have gas in the oil?
Maybe a whole carb cleaning might be in order.
(( racing is the only sport that you need two balls ))
Clean, no oil
Same as with.
Nope and nope
This should help, I think. After seeing a carb diagram, I realize the air I squirted into it may have karked up the jet and/or needle and seat in the carb.
Thanks,I'll let you know how it goes
jeff
I find that on these small engines, That have been setting up for a couple Mo. if i take & put a STRONG dose of SeaFoam in the Gas, ( 4 oz) or so it cleans up the gunk in the Carb.
LakeRat
