help diagnose
ugabulldog
Battery has 12 volts, engine will turn over but barely. see video, Does this sound like starter? Thanks
[video]https://www.facebook.com/100009751811141/videos/a.709302999404754/709303009404753/?type=3[/video]
Update on my post........... Take the plug or plugs out of the engine and try to turn it with the starter........ If it will turn over then a valve adjustment will be in order......
Let us know Mon Ami ~!~!
SidecarFlip
In reality 12 volts don't cut it. I fully charged wet cell battery should read around 13.5 volts, nit 12.
sgkent
watch the voltage when it cranks. Often a battery might show 12V but when it cranks it might drop to 8V or 9V is it is discharged. As the last post said, a fully charged battery is higher than 12V. You can also pull the spark plug to be sure it doesn't have water or fuel in the cylinder locking it up.
