davbell22602
- Nov 27, 2011
- 1,324
Replaced wiring harness, starter turns over when jumping solonoid but acts if the battery if half. Same with when jumping the starter with jumper cables directly. Removed spark plugs and engine spins like nothing holding it back. Took starter off and found corrosion and rust around the retainer brushes. Put another set of retainer brushes and no change when jumping starter. Will not turn over when using key. Got 12.4 at the hot side on the large post on solonoid. 12.4 at stud on the starter. The solonoid has 2 large and 2 small posts.
18hp L head twin Briggs
46in deck
148-818-372/F228d
46in deck
148-818-372/F228d
