Heat problem with blade engagement
Cbevv
Hi. I have a cub cadet 1525. When I start the mower for the first time and engage the blades, it works fine. Once the mower gets warm, if I disengage the blades, it will not re-engage until I turn mower off and allow it to cool for 10 minutes. I had an issue a while back with it not engaging. I replaced the relay and it fixed the problem. I replaced the relay this time and it did not fix the problem. Any suggestions?
If you have the clutch with the three adjusting screws you may try adjusting the gap to .012 all the way around and see if it helps.
