jonesandjones
- Aug 24, 2013
- 3
- 11
I'm having a hard time starting the engine on my 15yo Ariens walk behind mower (911-070). I have replaced the coil and kill switch. Now I have good spark. I have replaced the plug. The engine runs great once I get it going. The problem is starting it. After several tries it will start, run for a few seconds and die. If I can get it started and play with the automatic choke for quite a while, it will start running and runs fine. Once I shut it down, the problem starts all over and I have to go through the same routine. I hope this is a carburetor problem and not something internal (valves?). I'm contemplating a new mower, but I would really like to get this running as the transmission is still in good shape. If it's only a carburetor problem it is worth repairing. Any help would be very much appreciated.
JJ
JJ
