MStanfield
Hey guys, new to forum
I have a 1500 Ferris with the H721 V with 425 hours. When throttle is opened quickly, I get backfire thru carb and stumble. Also seems low on power...first thought a fuel problem. I have:
Installed new champion plugs
New Fuel Filter
Good fuel flow to fuel pump
Pump seems strong (although I have not tested volume...not sure amount needed)
Adjusted valves
Disassembled carb and cleaned
Checked spark with in-line tester; seemed ok
Partially opened choke...no improvement(floods out like you'd think)
Added Seafoam to tank
Checked compression...forget the numbers but over 100 psi each cyl
What else should I check?
New Fuel Filter
Adjusted valves
