gxv140 Rebuild Question - do I go further?
KC_kid
I had a problem last fall where something seemed to break inside the engine - loud banging internal to the engine. I shut it down before any catastrophic failure happened and the engine did not seize. I decided to open it up and have a look to see if I could fix it.
I pulled the engine and removed the oil pan and found that the bolts holding the connecting rod assembly to the crankshaft where backed out so far the lower cap was almost completely off. You can see in the picture where the bolts are backed out.
My question is: do I continue tearing down the engine or just tighten the connecting rod bolts to spec and put it back together? Right now the only new parts are a oil pan gasket and maybe a lower oil seal, I haven't even removed the head. I could remove the head to see what's going on and then potentially replace the rings, they cost $20. But I've never deglazed or honed cylinder walls before.
Any suggestions? I have had a lot of overheating problems with this mower in the past. I think I fixed it by no longer running higher octane fuel. Also notice how dirty it is, very sludgy oil, I suspect from overheating. This oil is less than 1 season of mowing in kansas city area.
BlazNT
I dont see any metal shavings in the oil. Did you find any?
KC_kid
There was definitely some tiny bits of metal in the old sludgy oil, like metal dust, very fine. I poured some Seafoam to release some of the sludge and the mixture that came out had the metal dust in it.
I think I've convinced myself to go ahead and remove the cylinder to hone and replace rings. I might as well since I'm into this far and the engine will be 16 years old this spring. I hope to use it for many more years.
BlazNT
I think you are going the right direction if you want to keep it.
Pull it apart fully and at a minimum replace the rod.
Once the bolts get a little loose it pounds against the journal and goes flat.
having gottem that loose it will have stressed and there will either be visible cracks or subsurface cracks.
Whne you get it out, break it in 1/2 so it never gets accidentally reinstalled.
A new rod is not expensive in fac down here the rebuild gasket kit is more expensive than the rod.
Before you push the piston out of the top of the bore, clen off the ridge of hard carbon at the lip or you will damage the rings and piston beyond repair
Clean out the crankcase good enough to eat off it and then buy a spray on crack detecor kit.
Google Turco Crack detection and you should find a supplier.
Most real auto parts stores carry them, you know the ones that have more engine parts than flashy mirrors and disco lights.
Check any spots where it looks like and impact has happened also the boss where the crank & cam run.
Any time I get that deep into a motor I take the oppertunity to fit new rings as the cost is minimal and that will add another 5 years or so to the life of the engine.
Finally your engine is getting way too hot judging from that photo so check the goverened fast idle speed when you have it back together and make sure you keep the surface of the engine clear of debris so the cooling air can do its job.
KC_kid
Thanks for the info, I'll put a new rod on my list of new parts and thanks for the tip with removing the piston.
I see that you feel there must have been a big impact on the engine, do you mean externally like something hit it or do mean internally from the rod banging around? I get the idea to look for cracks in the case but I'm not aware that it took any impact. The loud banging I heard started all at once. I was mowing the yard for about 30-45 minutes and then the banging started, then I immediately shut it down. I tested the rope to make sure it wasn't seized and it actually started back up, and I shut down again immediately. It probably didn't operate for a total of 10-15 seconds banging like that. I'm surprised to see those bolts so loose with it happening so quickly.
For the overheating... in 2014 I was running 91 octane fuel and the mower would overheat and stop running during every use. I couldn't figure it out and I finally pointed the finger at the higher octane fuel. Not really sure if that was the real cause because I still feel like it was getting too hot throughout the 2015 mowing season even though it never overheated to the point of shutting down. See my thread about that, I replaced about everything I could external to the engine - coil, filter, carb, spark, cleaned, flushed tank etc. I still don't know what was causing the overheating issue and I'm worried that it will continue after the rebuild.
http://www.lawnmowerforum.com/honda-forum/28935-gxv140-overheating.html
For cleaning the internal of the engine, what product do I use to accomplish that? I don't want to use the wrong thing and ruin it.
Thanks for all the help!
KC_kid
I don't have a puller so I couldn't get the fly wheel off, I'll have to borrow from the parts store puller tomorrow. Please advise per the photos... I have a bad feeling about what is possible to save. The bearings look pretty bad and the piston has some major scoring on one side. The bore doesn't look as bad as the piston and I'm not sure how bad the rod journal is. I have more pictures if you want to see them.
Can anyone explain my options? Do I need to find a replacement engine or is a replacement even an option? I'd like to find something with the hydro-static transmission output shaft.
KC_kid
HR215 K1 HXA MZAM-6263557
GXV140 Serial GJAB-7520228
Pison is scrap
Rod is scrap
Barrel looks suspect
Crank will clean up with a dip in hydrochloric acid, also called muriatic acid followed by several washes in clean water followed by chlorine and a hot water final rince.
Chlorine & acid will come from a pool company standard chemicals for adjusting the pH of your swimming pool.
If the scrathes in the bore are deep enough to catch your fingernail then it will need to be bored out to the next oversize and an ovesized piston fitted
The dark brown stains are the result of very heavy overheating and unless you were mowing for 3 to 4 hours strait in 80 deg air temperatures were due to something a lot more sinister than too high an octane fuel.
Most likely an air leak between the carb & engine or judging from what I can not see insufficant oil circulation.
What does the crown of the piston look like and the inside of the piston crown.
What actually was happening is the engine was getting way too hot and the rod was expanding enough to stretch the bolts slightly.
when the engine cooled down, the bolts were then too slack so not enough oil was retained around the journal which again got way too hot stretching the bolts and collapsing the area around the nuts on the rod.
The cycle continues the rod then gets looser till the vibrations are enough to unwind the nuts and you end up where you are now.
What is missing from the photo is the dipper, a little scoop type of thingie that splashed the oil all around the engine so some can drop into the holes and lube the bearing.
AFAIK Honda use a steel cap that fits under the rod bolts to dip the oil and this has a couple of tabs that fold up to stop the nuts backing off but Robert is the one to confirm this.
If they are missing then you might have a warrante claim if it can be established the engine has not been apar before & there was no dipper fitted ex-factory.
Without a dipper the engine will drastically overheat first at the little end then at the big end then usually sieze & break a rod.
The oil thicken as you suggested in your first post which again adds to the lack of circulation problem till eventually it goes bang & stops.
robert@honda
I do not think the GXV (vertical shaft, lawn mower engines) in the HR215 had a dipper on the connecting rod cap. A dipper was usually included on horizontal-shaft engines (pressure washers, reel mowers, generators, etc.) This is not a 100% hard & fast rule. I have seen some mower engines that do indeed have a dipper, but it was included to reduce overall costs, by sharing the same connecting rod cap as a horizontal-shaft engine.
