A little update on the PTO not engaging. Not knowing the previous owner had jumped out the reverse switch so he could mow in reverse. The jumper wire fell out of the reverse switch connector. Without the reverse switch connected cable was open circuit as if the reverse switch was made. Hope this post update will save someone some trouble.
