Grinding noise or metal sound when blade engaged
JimP2014
Hello this is the latest just replaced the mower deck belt with the identical one and the belt is perfect but there's this weird noise when engaging the blades it might be a pulley I don't know what it is but individually they all spin when you remove the deck completely away from the machine it's just everything's all hooked up the problem seems to surface but this is it if anybody has any ideas based on sound I would appreciate it greatly.
JimP2014
I believe that they all rotate perfectly the pulleys just based on what you're hearing does it sound like a specific pulley? Or something else?
Thanks,
Jim
JimP2014
Today I should be getting another brand new spindle + maybe I don't need it but this Craftsman lt 2000 42-in deck will now have two brand new spindles made a video yesterday where there's a grinding noise + the more I thought about it it's possible because I reduced the tension on that spring for the PTO lever itself so I'm wondering if the transition from the brake against the pulley to no break against the pulley it's taking a lot longer and that is the grinding noise that I'm hearing I imagine when you move that lever to engage the blades that the break should be completely away from the pulley and very quickly but I'm not positive but it's just something if someone reads this it might help them. So in summary I think by adjusting that slide bracket which mounts to the mower deck clutch that there's a lot more play in it it could be preventing the brake from moving away from the pulley very quickly. So it's just that slide bracket so a slight movement of the PTO lever causes the pulley brake to move away pretty much right away.
Jim
JimP2014
Latest video and mostly audio. I have replaced both spindles, brand new belt and only one pulley. Everything seems to spin fine, meaning 2 pullets, 2 spindles and one belt.
The audio when using a phone is much louder for some reason.
It might come down to someone who has heard this many times before, but that ain't me.
Jim
JimP2014
So today the same problem when you engage the blades there's this grinding type of noise then it goes away and then it's a constant metal kind of noise with spinning blades or spindles or pulleys whatever but what I'm wondering the mower deck has two pulleys + if you look at each pulley one has a shaft that is raised and one has a shaft that is recessed maybe I have those on backwards maybe the schematic from Sears is incorrect I will be looking at tomorrow I wonder if anyone with an LT 2000 mower deck 42 in ran across the same problem with the pulleys they don't seem to be identical at all
Jim
JimP2014
Jim
What I mean to say is in all the schematics on paper one seems raised shaft and the other seems recessed shaft I got to figure out what I got going on on my mower deck I don't know the answer that one right now but that might be part of it so when the grinding noise goes away after a couple seconds then there is this constant spinning metal grinding noise high pitched
