Greenworks mower for 5k sqft Yard
mk26
New member and new homeowner as well so please go easy with me,
I am looking at the below battery operated lawn mower for my 5k sqft yard, please help me decide which one to buy or any recomendation would be appreciated.
1. Greenworks GreenWorks 25272 36V Lead Acid Cordless 19" Self-Propelled Mower around $300++
2. Greenworks GreenWorks 25322 G-MAX 40V Cordless 16" Mower-40V 4 AH Li-Ion Battery Inc. around $280
Thank you
Thank you
I would buy gas mower better hen batterys
Thank you for the reply, is there any reason you say Gas mower better than Battery ? I was thinking battery operated will be hassle free of storing gas and oil at my grarage
Well gas or battery I still gotta store stuff ether way but gas is a little better because more power and longer run times :thumbsup:
I received as a fathers day gift the Greenworks 40V Lithium dual blade 19" 25302 yesterday. I trim 1.5 acres and yesterday was able to trim it all without a recharge. I used the grass catch bag instead of the mulching option which of course added weight and likely quicker battery discharge. Normally I would use the mulching option (included) for this trimming.
The beauty is that it has two batteries and discharges one and then switches to the other. If needed you can charge the discharged one while you continue to mow. It takes something less than an hour to charge the battery. I wanted to fully discharge both batteries for the first time so I mowed extra. Setting the cutting height is a snap using ione handle. i would recommend Lithium power and the dual battery. So far so good. It retails at Lowes at around $329.
Jim
Greenworks 40V Lithium dual blade 19" 25302 mower is around $400.00 not near $300 that's why I just ordered GreenWorks 25322 G-MAX 40V Cordless 16" Mower-40V 4 AH Li-Ion Battery Inc for $290 as I have a smaller yard. hope this will keep up well for me.
Jim
Jim
Very nice I would think mulching would make the engine work harder because not only does have to cut the grass but then process it and push it down. While bagging is just cutting. Unless its self propeled then ignor what I said
