Great Dane Chariot 61" = Deck Height Quick Adjustment
graydog
  • / Great Dane Chariot 61" = Deck Height Quick Adjustment
The Great Dane Chariot 61" has a terrible system for setting the deck height. It has a pin with a knuckle-busting ball that is hard to change to a different hole. I made a plate with notches and then a dog to drop into those notches using the existing lever handle. It is really easy and fast to raise the deck or drop it down. I can lower the deck in lighter grass and raise it when cutting in heavy stuff or over a rock.
The plate was quit a bit of work cutting and filing the notches, but the rest was easy. It did require drilling 2 holes in the lever. The photos should be self-explanitory. Click on photos to enlarge.
Great Dane Mower 2.jpg......GD Deck Lever 1.jpg......GD Deck Lever 2.jpg......GD Deck Lever 3.jpg.
exotion
Nice! Well done :)
SeniorCitizen
Good job. :thumbsup: Get a patent before dane sees it. Binders back in the 20s had a similar header height adjustment.
graydog
Thanks exotion and SeniorCitizen.
demhustler
nise job, G
add a foot pedal to quick up-and-down deck while going ower the rocks (or you have it?)
graydog
nise job, G
I don't have it & it's not necessary. Thx anyway.
What is your avatar picture ?
gregmartin
I like it, good design looks likes it works well.
gregmartin
I also have a GREAT DANE SUPER SUFER that I'm working on, hear is some pics of it when I got it,I'll post the after pics when I'm done with it.
