Hi Again:
I found the correct replacement for a flywheel for my model 5239 that is equipped with a D 408 engine. The problem is now the governor lever is rubbing on the bottom of the flywheel when the engine is turned over. It is rubbing right at the crease tht is provided for fine tuning the speed. The orginal flywheel worked great but was replaced due to having a crack in the keyway.
Could this be caused by the rest of the governor parts being "worn out"? I can not see how the new flywheel is any different than the old one since they both have the same part number! I guess that I could sand the bottom of the flyweel enough to prevent this, but would this be a good idea? I remember that there was something that held the governor lever down away from the flywheel. Could this be the key that is not holding the entire assembly down like it used to?
What is the problem?????
Tia,
Franchi
Tia,
Franchi
