have cub cadet model 127 with Kohler engine. how do I know where to set the govenor to get the max. power with out blowing the engine up?
Seeing that you do not post a Kohler model number, I would not set the no load speed at no high that 3400 RPM's. If it is a Kohler Courage engine I would reduce that to 3200 RPM's. I am assuming that you have a good quality tach and you know how to adjust the governor. The only Kohler engine that I know of, that run high than 3600 RPM's were the old K-series.
you are right, it is a Kohler engine, model K301A. thanks for the information.
