Delrin is an excellent choice. I keep the threshold savers from new door units. Its very hard, has a great lubricity and wear factor.
I wouldn't have thought you should have to remove the engine to get to everything you need to. But then, it may be easier and faster. Just take your time and think it thru, you'll overcome.
The bolt for the bushing in the arc-shaped slot is way back from the edge of the support plate, which is mounted closely under the mower frame.
This makes things virtually impossible to access with a wrench (maybe a specially bent wrench) due to angles and interference with the engine.
And, in order to repalce the main drive belt, the engine pulley has to drop down so that the belt can clear the keepers. Even though I used never-seize
when I replaced that pulley the first time,it still won't budge. Hence another reason to pull the engine, which really isn't that bad of a task.
Thanks again..........
Ron,
The steering in my MTD Yardman was much the same as you have described. It seemed to have been designed that way. The only major effort I made was to make a steel bushing that fit over the pin on the steering gear arch, that the steering rod end would still slip (tightly) over. That improved things, but as you and mhavanti have discussed, all of the steering components fit together very loosely. I have considered building up the ends of the remaining tie rods with weld and then hand shaping them to improve their fit, but I got involved with rebuilding the transaxle and stopped worrying about it. I can steer it and the bushing I made improved things enough to satisfy me. I will be interested in reading about how the improvements you've made work out.
Roger B
I can't help but think that some slop was intended.
However, sometimes the critter just won't turn as sharply as I think it should.
I have found that a tad of toe-in helps the turning radius, but things have become so sloppy that action is required.
And, sometimes when the steering is turned to right or left lock, one wheel will flop into a right angle position
and the whole shebang comes to a halt. Very disturbing.
I may get some bushings for the rod ends to do as you did, then capture them with larger washers over and under.
That's probably gonna be another McMaster Carr order...........
Thanks for your comments, and I will advise the ultimate outcome.
Thanks for your comments!
