Generic p-washer won’t restart after shutdown
I have a Generac
G0079540
motor number ST168 F2 A7
It will start cold, run as long as I want to use it, I shut it down, it will not restart. It will not restart with starting fluid, either.
I initially did the following after winter storage:
Fresh gas
cleaned the carb
Changed the plug
Plenty of fuel out of the line
I am seeing no spark, but only after I shut down.
Magneto/coil time, or is there something else with these motors?
It runs good initially, smooth, plenty of pressure on the pump side, but won’t restart until a very long cool down, and then very difficult to get it started.
Thank you in advance for your insight and help
