Yes, 105a is the needle - I'm afraid I'm not very good with the terminology! But the spring isn't superfluous - it's an integral part of the assembly. See attached diagram - it's crude, but you get the idea. Although the bowl "shares" the gasket with the float frame, the bowl does not in fact hold the float frame tight against the gasket. So without the spring, gravity would make the float frame fall away from the gasket and rest in the bottom of the bowl.
I think this is poor design - the bowl itself should hold the float frame in place. And the design (bad as it is) is poorly executed since there is nothing to hold the spring in place - you cannot reattach the bowl unless the carburetor is upside down. There is nothing to hold the spring in the float frame recess, and nothing to hold the spring in place in the bowl, so gravity works against you.
(I've removed the float mechanism itself in order to simplify the diagram - it attaches to the float frame and pivots up and down independently)
