mystreba
Yes you can get and you should have a set.... at lowes or any place that sells tools.
My generator has the same set up but it has a drain on the carb bowl.
I suggest you go to walmart and get the B12 Chemtool carb cleaner, best I've found. You know it's good when it burns the cr@pp out of your hand if it gets on it.
Take some more pics of the carb on the motor and post before you give up. This is probably no big deal. Even if you have to replace the carb you will probably spend less than what the shop will charge.
At this point I'll have to order the carb overhaul kit, since I'll probably need new gaskets after taking it off/apart. Meantime, I'll try to find the tool.
Here's a link to the carb parts schematic. Page 4. I have the Nikki.
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=18nqxGXBnfBhU7y
Anyone have any suggestions for retro-fitting a drain into this bowl? It seems to be some kind of cast aluminum.
