- Sep 7, 2024
- 3,406
You are starving for fuel under load. Most of the time that originates at the fuel tank or garbage in the fuel line. Some fuel lines collapse around areas with bends in them.
The other issue is if one cylinder is not producing power. The engine will not shake; it just loses power. A bad plug or a coil is suspect when this happens.
