Fuel tank clean out?
Would like to hear more on this?? Just what do you do mix it with hot water. Will it devolve the old hard dried up gas? I have a tank now that I just can't clean so I will try it. I have found if you don't get that old dried up gas out it just plugs the filter as fast as you can change it.
The Apple Vinegar did a good job! Raised with alcohol and installed. Engine ran for 10 min. with no problem.
Filter is clear.
LB
