Re: fuel pump issue FIXED
Thanks to those who have helped--wanted to let you know what was wrong. I tore down the carb once before expecting to find the main jet clogged but found noting wrong. After much other work, I decided to check the carb again, and although I saw nothing wrong at first, I hooked up a length of hose to the fuel inlet and blew through it. I heard a kind of sputter sound, so I used carb cleaner spray and then compressed air to blow out the inlet (ie: thorough the seat of the needle float valve). Never saw anything come out, but after doing this I then blew with my hose by mouth and the sound of sputter was gone. Unit now runs as it should (happy dance).
