Fuel line ofr SRM 200CE
richie25rich
Hi, thanks for the tip to convert the old air filter to a box type. I did find another air filter locally, but now the fuel line broke in half, it was brittle, it appears to be around 1/8 inch inside diameter and 3/16 inch outside diameter. Stores claim it is an obsolete part and do not carry. Know of any local chains stores that carry this oddball tubing size? Thanks, Rich
exotion
All fuel lines for small trimmers are the same get some from a dealer or any auto parts store. Even home depot has some
Just be careful when you buy fuel line as it comes in two or three different wall thickness.
Thin wall for return line, heavy wall for suction lines.
Use a drill bit to check the ID .
