This is a new to me mower that ran and cut great the first several times I used it. The last several times it starves for gas and requires choking to get back to the shop. I have done most of the obvious things.......
New fuel filter, checked tank venting, cleaned lines, and cleaned air filter. Ran w/ gas cap loose and also with no air filter and no change.
If I blow air back into tank until it just hisses out through cap vent then quickly reattach filter then the mower starts and runs fine......generally long enough to cut entire lawn. The pressure in tank primes the pump believe.
I am going to replace fuel pump but is the a better candidate for cause of problem? Is there anything else that would cause pump to lose its prime and run the filter dry? Pretty sure tank and lines are fine.
I had posted on small engine repair but no suggestions.
Yth 2548
Kohler cv730
Yth 2548
Kohler cv730
