Fuel Delivery Issue When Hot...I think
Well, I just pulled the fuel line off, right at the entrance to the petcock (fuel shutoff). Embarrassingly, the petcock is almost completely stopped up.
Drain and flush your fuel tank, install all new fuel hose and filter. Make sure she is spotless all the way to the carb inlet. Good flow AT the carb inlet.
Here's another one. What type of fuel can spout do you have? Open top or a new style EPA pain in the rump to dispense spout? Middle spout is pretty good.
Open spouts let bugs, leaves, grass, dirt, grit, water and trash into your can. Then when you fill the mower tank, all that trash passes to the mower tank. Said trash passes to the carb. Think I'm the only one on here preaching about open top spouts.
Problem solved! The fuel cutoff valve was almost completely clogged. Replaced it and cleaned out the tank. Runs like a champ now.
I suppose that with the limited fuel, the carb was compensating and running very lean, leading to running hot and vapor lock the fuel.
And Slomo, I checked all my cooling fins and they are actually quite clean.
And once I started looking for valve clearance specs, realized mine are hydraulic lifters, so no adjustment required. Really glad as I was feeling quilty/stupid for not ever checking them.
Sincere thanks for all the great help! This forum is great!
Calling BS on this one. I bet if you posted up a couple pictures, she is filthy. :p (y) Ok, I'll take your word on it. LOL Did you look all the way around the cylinder/s? All clean and clear?
OK, I’m busted. I didn’t look all the way around the cylinders. 😔
Removal of all the covers on this mower is quite an undertaking, so I conveniently convinced myself all is good since the portion I could see looked so good. Amazing how the lazy mind can be so convincing when…convenient.
So I hereby promise to do so…once I get my yard cut. 😉
Thanks again for your help.
Might be a pain but IF possible that pan needs removed. It sits tight around the fins and can pack up easily. Sure can kill air flow in a hurry.
IF you must pull the engine to get this air flow cooling pan shroud deal off, I would anti-seize all the bolts and pulleys. Make it easier for the next person.
